주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iMac G5 17" Model A1058 Upper Left Fan Replacement
필요한 것
  1. iMac G5 17" Model A1058 Upper Left Fan Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Upper Left Fan Replacement: 2 단계, 이미지 1/3 iMac G5 17" Model A1058 Upper Left Fan Replacement: 2 단계, 이미지 2/3 iMac G5 17" Model A1058 Upper Left Fan Replacement: 2 단계, 이미지 3/3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 17" Model A1058 Upper Left Fan Replacement, Fan Cover: 3 단계, 이미지 1/2 iMac G5 17" Model A1058 Upper Left Fan Replacement, Fan Cover: 3 단계, 이미지 2/2
    • Remove the two Phillips screws securing the fan cover to the midplane.
    • The shouldered screw belongs in the lower left corner of the fan cover.
    • Lift the fan cover up off midplane.
  4. iMac G5 17" Model A1058 Upper Left Fan Replacement, Upper Left Fan: 4 단계, 이미지 1/1
    • Disconnect the hard drive data cable connector from the logic board by pulling its connector straight up.
  5. iMac G5 17" Model A1058 Upper Left Fan Replacement: 5 단계, 이미지 1/1
    • Disconnect the upper left fan cable connector from the logic board by pulling its connector straight up.
  6. iMac G5 17" Model A1058 Upper Left Fan Replacement: 6 단계, 이미지 1/1
    • De-route the fan cable from around the edge of the logic board as necessary.
  7. iMac G5 17" Model A1058 Upper Left Fan Replacement: 7 단계, 이미지 1/2 iMac G5 17" Model A1058 Upper Left Fan Replacement: 7 단계, 이미지 2/2
    • Remove the two T8 Torx screws securing the upper left fan to the chassis.
    • Lift the upper left fan out of the chassis.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Walter Galan
694,495 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 7,750
