소개
Front bezel damaged beyond repair? Use this guide to replace it.
필요한 것
이 단계에 사용된 도구:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Lay the bezel front side down on a table.
If necessary, peel back the tape covering the camera board.
Use a spudger to pry the microphone off the adhesive holding it to the front bezel.
다른 2명이 해당 안내서를 완성하였습니다.
