이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Disconnect the hard drive thermal sensor by pulling the connector away from its socket parallel to the face of the hard drive.
Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself.
Lift the hard drive off its lower pins and pull it out of the rear case, minding the cables that are still attached.
Insert the flat end of a spudger into the gap between the SATA power connector and the hard drive.
Twist the spudger to separate the SATA power connector from the hard drive.
Pull the SATA power connector away from the hard drive.
