소개
Use this guide to replace the monster 20" LCD housed within your iMac.
필요한 것
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Remove the following three screws securing the inverter to the chassis:
Two 7.9 mm Phillips.
One 26 mm Phillips.
Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
Remove the two 7.3 mm shouldered Phillips screws securing the display cable connector to the logic board.
다른 18명이 해당 안내서를 완성하였습니다.
Some models (with light sensor) have only the two outboard screws.
Robert Huber - 답글
