주요 콘텐츠로 건너뛰기
iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Disconnect the hard drive thermal sensor from the top edge of the logic board.
    • Pull the connector parallel to the face of the logic board.
  2. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Remove the two 9.2 mm T10 Torx screws securing the hard drive bracket to the rear case.
  3. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Lift the hard drive from its left edge enough to clear the inverter and pull it toward the left edge of your iMac to unseat the mounting pins from the chassis.
    • During installation, do not push the rubber grommets through the chassis with the hard drive mounting pins as retrieving them will require removing the logic board.
  4. iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 4 단계, 이미지 1/2 iMac Intel 20" EMC 2105 and 2118 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Pull both the SATA power and data cable connectors away from the hard drive.
    • Be careful when de-routing the hard drive thermal sensor cable from under the heat sink framework.
결론
Walter Galan
694,561 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,304
