주요 콘텐츠로 건너뛰기
iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement
  1. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement, Power On Button: 1 단계, 이미지 1/1
    • To get to the power button first remove the hard drive fan as seen in other guides.
  2. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 2 단계, 이미지 1/1
    • This is a picture of the button in place with the connector to the logic board removed.
    • There are three plastic pins protruding up from the main back case that the button fits over. They appear to be slightly melted and mashed to hold it in place. I used a pocket knife to pry it up and off the posts.
  3. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 3 단계, 이미지 1/2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 3 단계, 이미지 2/2
    • Here it is with the back plate of the button pried off. This exposes a white plastic washer under it.
  4. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 4 단계, 이미지 1/1
    • The center of the washer has a center locking pin to correctly place it on the back of the button. The washer is concave and the concave side faces the button, This gives the button a spring to it so that it will pop back out.
  5. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 5 단계, 이미지 1/2 iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 5 단계, 이미지 2/2
    • This is he back of the button that will now just push out. Picture #2 is with the button removed.
  6. iMac Intel 20" EMC 2105 and 2118 Power On Button Replacement: 6 단계, 이미지 1/1
    • Test the button to see if it works.
    • After replacing the button, use something (like a low temperature soldering iron) that will melt the tops of the white plastic pegs to secure the button in place.
결론
다른 4명이 해당 안내서를 완성하였습니다.
mayer
회원 가입일: 01/04/10
685,379 평판
안내서 12개 작성하였습니다
MacHale Enterprises MacHale Enterprises 회원
Business
1 회원
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 35
전체 시간: 13,866
