주요 콘텐츠로 건너뛰기
iMac Intel 20" EMC 2105 and 2118 RAM Replacement
필요한 것
  1. iMac Intel 20" EMC 2105 and 2118 RAM Replacement, Access Door: 1 단계, 이미지 1/2 iMac Intel 20" EMC 2105 and 2118 RAM Replacement, Access Door: 1 단계, 이미지 2/2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac Intel 20" EMC 2105 and 2118 RAM Replacement, RAM: 2 단계, 이미지 1/1
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  3. iMac Intel 20" EMC 2105 and 2118 RAM Replacement: 3 단계, 이미지 1/1
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
결론
To reassemble your device, just follow these instructions in reverse order.
다른 62명이 해당 안내서를 완성하였습니다.
Walter Galan
684,330 평판
안내서 1,203개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 32
전체 시간: 36,080
