주요 콘텐츠로 건너뛰기
iMac Intel 20" EMC 2133 and 2210 Access Door Replacement
필요한 것
  1. iMac Intel 20" EMC 2133 and 2210 Access Door Replacement, Access Door: 1 단계, 이미지 1/1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
    isn't it actually pc2-5300s ?
    grze - 답글
    It is for the 2133, the 2210 uses 6400
    maccentric - 답글
    There are comments elsewhere in this step by step re. the bezel removal. That step does NOT show how to remove it. Well, take the 5:39 secs to watch the above video. It clearly shows how the aluminum framed bezel easily comes off once you've seen it done. To whoever decided to preface these instructions with that video, thank you.
    ECJohansen - 답글
결론
다른 36명이 해당 안내서를 완성하였습니다.
Walter Galan
694,650 평판
안내서 1,203개 작성하였습니다
댓글 2개
Situs Tuandomino adalah agen poker online yang sangat di percayai memberikan tingkat kemenangan yang begitu tinggi dalam memenangkan permainan Game online di Indonesia
tuansakong99 - 답글
Spam isn't cool.
Jason Zak -
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 12
30일 전: 22
전체 시간: 22,446
