소개
Remove your access door to replace RAM chips or to open the case of your iMac.
필요한 것
Loosen the single Phillips screw in the center of the access door.
Remove the access door from your iMac.
다른 36명이 해당 안내서를 완성하였습니다.
댓글 2개
Situs Tuandomino adalah agen poker online yang sangat di percayai memberikan tingkat kemenangan yang begitu tinggi dalam memenangkan permainan Game online di Indonesia
Spam isn't cool.
isn't it actually pc2-5300s ?
grze - 답글
It is for the 2133, the 2210 uses 6400
maccentric - 답글
There are comments elsewhere in this step by step re. the bezel removal. That step does NOT show how to remove it. Well, take the 5:39 secs to watch the above video. It clearly shows how the aluminum framed bezel easily comes off once you've seen it done. To whoever decided to preface these instructions with that video, thank you.
ECJohansen - 답글
