주요 콘텐츠로 건너뛰기
iMac Intel 20" EMC 2133 and 2210 RAM Replacement
필요한 것
  1. iMac Intel 20" EMC 2133 and 2210 RAM Replacement, Access Door: 1 단계, 이미지 1/1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 20" EMC 2133 and 2210 RAM Replacement, RAM: 2 단계, 이미지 1/2 iMac Intel 20" EMC 2133 and 2210 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 20" EMC 2133 and 2210 RAM Replacement: 3 단계, 이미지 1/1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
결론
다른 163명이 해당 안내서를 완성하였습니다.
Walter Galan
686,574 평판
안내서 1,203개 작성하였습니다
12 댓글
I currently have a 4GB memory module installed on an EMC 2210 in one of the memory slots. Can I still install the original 1GB ram in the other slot making it 5GB total memory?
richt0812 - 답글
[|It depends on the model. Check here:] https://support.apple.com/en-us/HT201191
Alex Nos -
I installed 2GB x2 to mine to upgrade from 1GB x2. It took just minutes and I used a regular philips screw driver I found around home. Pull hard on the black straps to get the memory out. It is working great with no problems. Good luck!
1tom2go - 답글
Thank you for the guide. I had 2GB. I took out 1 module to add a 4GB module. So easy and now my 2133 iMac is jaw dropping fast.
Garison
garison - 답글
Hi Garison,
I hope you can answer my question. I have an iMac, medio 2007, Intel 20" EMC 2133.
RAM: (1GB + 1GB) 667 MHz DDR2 SDRAM.
I would like to make my iMac "jaw dropping fast" as well ;-)
Is it PC 5300 or PC 6400 I should buy?
And what setup wold you recommend? (1GB + 2GB), (1GB + 4GB), (2GB + 2GB) or (2GB + 4GB)?
Thanks,
Mikkel
mipedersen -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 36
30일 전: 111
전체 시간: 107,215
