이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Removing the hard drive.
필요한 것
To remove the hard drive bracket, squeeze the middle against the side of the hard drive while rotating the top left edge toward yourself.
After the left edge has been freed, rotate the bracket toward the right edge of the hard drive.
Lift the hard drive bracket straight up off the chassis.
Insert the flat end of a spudger between the SATA data cable and the edge of the hard drive.
Twist the spudger to separate the SATA data cable from the hard drive.
Disconnect the SATA data cable from the hard drive.
Lift the hard drive out of your iMac, minding the thermal sensor cable that may get caught.
