주요 콘텐츠로 건너뛰기
iMac Intel 20" EMC 2266 Optical Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iMac Intel 20" EMC 2266 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/2 iMac Intel 20" EMC 2266 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2/2
    • Peel the strip of EMI tape off the edge of the rear case.
  2. iMac Intel 20" EMC 2266 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Remove the two T10 Torx screws securing the optical drive to the rear case.
  3. iMac Intel 20" EMC 2266 Optical Drive Replacement: 3 단계, 이미지 1/1
    • If necessary, remove the piece of tape holding the thermal sensor wires to the hard drive.
  4. iMac Intel 20" EMC 2266 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
    • When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
  5. iMac Intel 20" EMC 2266 Optical Drive Replacement: 5 단계, 이미지 1/1
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the rear case.
  6. iMac Intel 20" EMC 2266 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
결론
Walter Galan
693,915 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 752
