소개
Replace a broken AirPort card to regain Wi-Fi connectivity.
필요한 것
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the flat end of a spudger to pry both AirPort antenna cable connectors up off the AirPort card.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
