주요 콘텐츠로 건너뛰기
iMac Intel 21.5" EMC 2308 Hard Drive Replacement
필요한 것
  1. iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Glass Panel: 1 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Glass Panel: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Display: 3 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Display: 3 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Display: 3 단계, 이미지 3개 중 3개
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
  4. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
  5. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • The vertical sync ribbon cable has a ZIF style end, but the socket has no lock or retaining flap. Simply pull the cable away from its socket toward the optical drive side of the iMac to disconnect it from the LED driver board.
  6. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
  7. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be careful when disconnecting and reconnecting this cable, as it is easily damaged.
  8. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  9. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  10. iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Hard Drive: 10 단계, 이미지 1개 중 1개
    • Before disconnecting the thermal sensor cable, take note of its orientation. It is extremely important to reinstall the connector reversed from the current orientation so the fans will not run at full speed.
    • Disconnect the thermal sensor by pulling its connector away from the side of the hard drive.
    • During reassembly, be sure that the thermal sensor connector is connected to set of pins closest to the SATA connectors. If the fans spin at full speed, reverse the connector's position.
  11. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 11 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 11 단계, 이미지 2개 중 2개
    • Disconnect the SATA data cable by pulling its connector away from the hard drive.
    • Use the flat end of a spudger to help disconnect the SATA power connector from the hard drive.
  12. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the two 9 mm T10 Torx screws securing the upper hard drive bracket to the outer case.
  13. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 13 단계, 이미지 1개 중 1개
    • Slightly rotate the hard drive out of the outer case and lift it up off its mounting pins toward the top edge of the iMac.
  14. iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Hard Drive: 14 단계, 이미지 1개 중 1개
    • Remove the two T8 Torx screws securing the upper bracket to the hard drive.
    • Remove the upper bracket from the hard drive.
  15. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the two T8 Torx pins from the other side of the hard drive.
  16. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 16 단계, 이미지 1개 중 1개
    • Carefully peel off the piece of EMI foam attached to the front of the hard drive.
    • Don't forget to transfer this to your new hard drive.
  17. iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Replace the hard drive with an SSD: 17 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Replace the hard drive with an SSD: 17 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Replace the hard drive with an SSD: 17 단계, 이미지 3개 중 3개
    • Follow the next steps if you are replacing your hard drive with an SSD kit.
    • If your SSD enclosure looks like the first image, follow this guide instead.
    • Line up the SSD connectors with the metal enclosure's sockets.
    • Press the drive against the enclosure sockets until the SSD is firmly seated.
    • The SSD connects with the enclosure in only one direction. If the connectors don't line up, rotate the SSD and try again.
  18. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 18 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 18 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 18 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to install the four silver screws (two on each side) along the edges of the SSD to secure it to the enclosure.
  19. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 19 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 19 단계, 이미지 2개 중 2개
    • Plug the included sensor-enabled SATA power cable into the enclosure's port.
    • The cable is keyed to connect in only one orientation. If you can't connect the cable, rotate it 180° and try again.
  20. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 20 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 20 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 20 단계, 이미지 3개 중 3개
    • Peel the white liner off the back of the small temperature sensor board in order to expose the adhesive.
    • Adhere the temperature sensor board to an exposed, metal surface of the SSD, close to the SATA connector.
    • Fold the excess temperature sensor wires so that they are out of the way while you install the enclosure.
  21. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 21 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 21 단계, 이미지 2개 중 2개
    • Use a T8 driver to install the mounting pins from the old hard drive onto the sides of the enclosure.
  22. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 22 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 22 단계, 이미지 2개 중 2개
    • Attach any mounting brackets removed from the old hard drive onto the enclosure.
  23. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 23 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 23 단계, 이미지 2개 중 2개
    • Connect the iMac's SATA power cable to the other end of the new sensor-enabled SATA cable.
  24. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 24 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 24 단계, 이미지 2개 중 2개
    • Connect the iMac's SATA data cable to the enclosure's socket.
  25. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 25 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 25 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 25 단계, 이미지 3개 중 3개
    • The images used in this step come from a 2017 iMac. Your cables may look slightly different, but the procedure remains the same.
    • Slide the SSD enclosure into the space previously occupied by the hard drive.
    • Route the SATA cables so that they will not interfere with any other components.
    • Try to keep the cables free from any sharp bends, and route them such that they are not pinched.
  26. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 26 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 26 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 26 단계, 이미지 3개 중 3개
    • If your motherboard has a socket for a hard drive temperature sensor, follow this step to plug the sensor wires in.
    • Find the connector on the motherboard labeled HD TMP or HDD TEMP.
    • If you have trouble locating it, trace the two-wire temperature cable you disconnected from the old hard drive.
    • If the previous temperature cable is still connected to the board here, disconnect and remove it. You will no longer need it.
    • Connect the temperature sensor's two-wire red-black cable to the motherboard plug labeled HD TMP or HDD TEMP.
    • The connector is keyed to fit in only one orientation. If it doesn't fit one way, rotate it 180° and try again.
    • Route the excess wire so it does not interfere with any other components.
결론
다른 384명이 해당 안내서를 완성하였습니다.
작성자
15다른 기여자 명과 함께
Andrew Bookholt
596,111 평판
안내서 619개를 작성함
67가이드 댓글
Make sure the hard drive is of the same producer and it has a temp sensor connector. It's the only way to ensure that the heat sensor connector will fit into the hard drive's socket. If you don't plug in the temp sensor iMac's HDD Fan will rotate at its maximum speed, ie. over 6000 rpms - the noise is extraordinary!!!
David Relich - 답글
I replaced my internal HDD on my 215" iMac, but the iMac can't get access to the new hard disk's (Seagate Barracuda Green) temperature sensor. The HDD fan in the iMac steps up the RPM, and over about 15min reaches 6000RPM (VERY loud) and stays there until machine is shutdown or put to sleep.
I found a fix for this: http://hddfancontrol.com/HDDFanControl/H... - this tiny piece of shareware software allows the iMac to see the temperature of the drive via S.M.A.R.T., and therefore the fans react according to the correct temperature again!
Ian - 답글
One thing Andrew left out here, which I discovered on my own, is that even if you have the temperature sensor connected to the correct pins, you ALSO have to make sure that it is 'oriented' properly.
On the sensor connector (the little head that plugs into the hard drive) I saw a little white dot on one side, which it turns out, indicates that's the 'top'. So on my iMac, you have to make sure when you connect the temp sensor connector with the white dot showing.
Otherwise, I got the 6000 rpm fans.
robert Seith - 답글
Success. For any interested people, it's about an hour - going slowly. Now that I've done it, I assume I could do it again in 15 minutes if I had to.
Just have the right tools handy, the T 8 and T 10 bits in particular. Getting off the display screen is easy. The screws are harder than you'd think because of the magnets, but they're not that bad. I recommend having tweezers to help pull them and place them later on.
Overall, the thing that worried me most was the fan issue. And, so far... it's not an issue. I had a seagate 500 gb, and I replaced it with a seagate barracuda 3 tb hhd. Everything fit right into it, just as it did into the original. No optical sensor needed. No new sensor needed, period. No software needed. Nothing. Just put in the new hd, and it works. I'm very pleased, and very proud of myself. Good luck to anyone considering doing this upgrade. You can do it, really.
Kevin - 답글
It's a pretty straightforward procedure. Took less than an hour. I replaced the 500GB Seagate Barracuda with a Seagate Barracuda 2TB, model ST2000DM001. So far, after about 30 minutes of use, it's working great, and I haven't had the fan problem, but we'll see what happens.
Kevin's advice about the tweezers for extracting and inserting the screws that attach the display to the case was right on (although I used a small pliers instead).
Before you begin the replacement procedure, I highly recommend putting the new drive into a hard drive dock, and restoring to it from a Time Machine backup. Try booting off the new drive once to make sure it works. Then, when you swap the new drive for the existing internal drive, it'll be ready to go with no further effort needed.
eshienbrood - 답글
댓글 쓰기
조회 통계:
지난 24시간: 102
지난 7일: 906
지난 30일: 2,121
전체 시간: 615,481
