주요 콘텐츠로 건너뛰기
iMac Intel 21.5" EMC 2308 Hard Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iMac Intel 21.5" EMC 2308 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Before disconnecting the thermal sensor cable, take note of its orientation. It is extremely important to reinstall the connector reversed from the current orientation so the fans will not run at full speed.
    • Disconnect the thermal sensor by pulling its connector away from the side of the hard drive.
    • During reassembly, be sure that the thermal sensor connector is connected to set of pins closest to the SATA connectors. If the fans spin at full speed, reverse the connector's position.
  2. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 2 단계, 이미지 1/2 iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Disconnect the SATA data cable by pulling its connector away from the hard drive.
    • Use the flat end of a spudger to help disconnect the SATA power connector from the hard drive.
  3. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the two 9 mm T10 Torx screws securing the upper hard drive bracket to the outer case.
  4. iMac Intel 21.5" EMC 2308 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Slightly rotate the hard drive out of the outer case and lift it up off its mounting pins toward the top edge of the iMac.
결론
Andrew Bookholt
586,715 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,750
