주요 콘텐츠로 건너뛰기
iMac Intel 21.5" EMC 2308 RAM 1333 MHz
필요한 것
  1. iMac Intel 21.5" EMC 2308 RAM 1333 MHz, Introduction: 1 단계, 이미지 1개 중 1개
    • So, here's the catch: this logic board officially only supports the DDR3 PC3-8500, which runs at 1066MHz, but that's not entirely true. Its 4 slots supports 1333 MHz. You can try other capacities over what was used on my setup, but I cannot guarantee that it will work.
  2. iMac Intel 21.5" EMC 2308 RAM 1333 MHz: 2 단계, 이미지 1개 중 1개
    • 3 slots running at 1333 MHz each.
  3. iMac Intel 21.5" EMC 2308 RAM 1333 MHz: 3 단계, 이미지 1개 중 1개
    • This is the configuration layout that you should follow (Livre means "Free"), otherwise it won't work in my setup.
  4. iMac Intel 21.5" EMC 2308 RAM 1333 MHz, Exact Models Used: 4 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 RAM 1333 MHz, Exact Models Used: 4 단계, 이미지 2개 중 2개
    • Please note that probably the only memories supported by the Logic Board in higher frequencies are the ones with 4 chips on front and 4 chips on the back.
    • 1 x 4 GB
    • 2 x 2 GB
결론
There's a chance that your iMac will power on with the coolers at maximum speed. If this happens, just turn the iMac off normally and remove the power cord from power, wait 20 seconds and power it on normally.
작성자
4다른 기여자 명과 함께
Gabriel
회원 가입일: 12/05/18
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 81
전체 시간: 1,296
