주요 콘텐츠로 건너뛰기
iMac Intel 21.5" EMC 2308 RAM Replacement
필요한 것
  1. iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: 1 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: 1 단계, 이미지 2개 중 2개
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
  2. iMac Intel 21.5" EMC 2308 RAM Replacement, RAM: 2 단계, 이미지 1개 중 1개
    • Use the sharp tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
  3. iMac Intel 21.5" EMC 2308 RAM Replacement: 3 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2308 RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
결론
다른 112명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Bookholt
596,117 평판
안내서 619개를 작성함
1가이드 댓글
There needs to be a little bit of important discucssion about getting the new RAM properly seated into the slots. Otherwise, great instructions!
Mary - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 23
지난 30일: 107
전체 시간: 90,356
