소개
Upgrade your RAM for an instant increase in speed.
필요한 것
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
거의 끝나갑니다!
결론
다른 111명이 해당 안내서를 완성하였습니다.
In order for the logic board to come out cleanly, one should remove the RAM at the end of this step.
kevmacmills - 답글
Definitely! The author should make this as a step in the description (because not everyone reads Comments)
finnik2d - 답글
Just did this procedure and the RAM must absolutely come out for the logic board to come free later.
matt - 답글
