소개
Use this guide to replace your Bluetooth board.
필요한 것
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the flat end of a spudger to pry the Bluetooth antenna cable connector up from its socket on the Bluetooth board.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
