소개
Use this guide to replace a broken camera.
필요한 것
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the two 5.2 mm shouldered T10 Torx screws securing the camera board to the outer case.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
