주요 콘텐츠로 건너뛰기
iMac Intel 21.5" EMC 2389 Glass Panel Replacement
필요한 것
  1. iMac Intel 21.5" EMC 2389 Glass Panel Replacement, Glass Panel: 1 단계, 이미지 1/2 iMac Intel 21.5" EMC 2389 Glass Panel Replacement, Glass Panel: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    구매
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
  2. iMac Intel 21.5" EMC 2389 Glass Panel Replacement: 2 단계, 이미지 1/2 iMac Intel 21.5" EMC 2389 Glass Panel Replacement: 2 단계, 이미지 2/2
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,715 평판
안내서 619개 작성하였습니다
댓글 한 개
My I Mac is a 2015 late model; are the screens all the same as long as they are 21.5"?
donehawk - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 71
전체 시간: 16,006
