이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95-
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
Pull the display data cable straight out of its socket on the logic board.
Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
Use your thumbs to push the IR board connector toward the top edge of the iMac and out of its socket on the logic board.
Pull the IR board out from behind the front face of the iMac's outer case.
Remove the IR board.
다른 2명이 해당 안내서를 완성하였습니다.
