소개
Replace the LED driver board to fix a non-functioning display backlight.
도구
부품
지정된 부품이 없습니다.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Remove the two 9 mm T10 Torx screws securing the LED driver board to the outer case.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
