주요 콘텐츠로 건너뛰기
소개
Internal Prerequisite.
부품
지정된 부품이 없습니다.
  1. iMac Intel 21.5" EMC 2389 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Remove the following four screws:
    • One 9.3 mm T10 Torx screw with a large head
    • Three 9.3 mm T10 Torx screws with a normal sized head
  2. iMac Intel 21.5" EMC 2389 Optical Drive Replacement: 2 단계, 이미지 1/2 iMac Intel 21.5" EMC 2389 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Pull the optical drive thermal sensor connector toward the top edge of the iMac to disconnect it from its socket on the logic board.
  3. iMac Intel 21.5" EMC 2389 Optical Drive Replacement: 3 단계, 이미지 1/2 iMac Intel 21.5" EMC 2389 Optical Drive Replacement: 3 단계, 이미지 2/2
    • Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
    • Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
  4. iMac Intel 21.5" EMC 2389 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Disconnect the optical drive cable by pulling its connector away from the optical drive.
    • Remove the optical drive from the iMac.
    • Do not forget to also move the thermal sensor from the optical drive to the enclosure when you install the second hard drive.
결론
Andrew Bookholt
572,449 평판
안내서 618개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 317
