소개
Use this guide to upgrade the RAM in your iMac.
필요한 것
Unplug your iMac's AC cord along with any peripheral devices.
Lay your iMac face-down on a soft, clean surface as shown.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door.
Gently slide the black plastic RAM pull tab out from the RAM slot.
Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
It is far harder than I thought you have to pull REALLY hard and then there will be a little click and than you can gently pull out the RAM.
Press really hard, to the point you think you’ll cut your thumb, you’ll hear a slight ‘click’. If it’s not properly installed, the iMac will ‘beep, beep, beep’ In protest upon booting…
Brian -
I found it best to make use of the factory ‘pull tabs’. Much much easier than trying to pull the ram out by hand. It may seem like a good idea but, don’t be tempted to use pliers.
Brian -
Thanks for your Useful guide …. iMac Intel 21.5" EMC 2428 RAM Replacement was performed step by step on my Imac and every thing is perfect right now.
I was able to remove one side of the ram, but the other side would not budge. I was afraid that I was going to rip the plastic tab out of the computer. Any suggestions?
is it completely manditory to take out the ram? why not just keep it in? for some guides for replacing other components you dont have to, but in some you do. why is this the case? does it have to do with not getting shocked because there is power stored in there or some other reason? i was just wondering tho...
Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture).
When reinstalling RAM in this machine or any iMac with upgradable RAM slots push hard to get them to go in (Apple really did make this one harder than it needed to be). If you don't push hard it won't go in and your computer won't work. (trust me on this learned the hard way)
I am having trouble with bottom 2 slots. As I get beeping sounds when using them. When removed it boots properly. I tried & tried to push the 2 , 2GB ram modules into the bottom slots BUT all get is beeping. Guess I have to settle for 4GB Rather than 8 unless someone has a suggestion.
Try swapping the to the other slots & don’t forget to press really hard until you hear the ‘click’.
Brian -
Is there an expirience to settle 1600 MgH Ram instead 1333 MgH manual required?
Added 16GB for a total of 20GB, runs great, do make sure of the “click”, the beep is disturbing
2x2 GB 1333 MHz RAM were installed as delivered. I couldn’t manage to get those two out of their slots. I don’t want to damage anything. So, I put 2x8 GB RAM 1333 MHz RAM bars in the other two empty spare slots to have 20 GB RAM in total. The iMac runs fine with it. As described above, make sure to push RAM until they ‘click’ in completely.
Why are we taking out the RAM modules just to put them back in on the next step ?
다른 65명이 해당 안내서를 완성하였습니다.
댓글 10개
Can i ad up to 32gb?
I need to know this as well.....
From what I read in the specs for this model it can support up to 16GB
You can't put 8GB modules in these slots. I tried. Apparently the architecture does not support addressing the extra memory in each slot. My iMac would not successfully boot or run for very long before rebooting. So, you have 2GB and 4GB module options, in pairs, among the 4 slots. That should provide 4GB (two 2GBs), 8GB (four 2GBs or two 4GBs), 12GB (pair of each) and 16GB (four 4GBs) options for total RAM.
I'm no expert, but this was my experience.
Larry -
My iMac is a i3 core, can I do the same thing with the same chips?
Thank you for the fix manual. I managed to change my memories in 5 minutes.
Tho it was a mistake to be in a hurry to try all, cause at begining I got the 3 beep warning and iMac didnt want to boot.
I opened again, tried 2x4GB instead of the initial 4x4GB, and it worked.... tried again 4x4GB but swaping memories (not that its something relevant but supposed helped me reconnect all better).
Now my oldie iMac has 16GB instead of 4GB and it works great.
Thank you!
Success! I don't have a lot of strength in my fingers and it took all of it to pull those tabs out, and then to push the new modules in but finally I got that pleasant feeling of the pins fitting into the slots the way they should. So the iMac has gone from 2 hardworking RAM modules to much zippier 4. Thanks for the guide!!
Hi everyone !
I’d like to boost my iMac 21,5”, 3.06GHZ, INTEL CORE i3 (>mid 2010) ; I already installed a new SSHD and I’d like to change the RAM. I have a few questions though :
The original RAM is 2GB DDR3 1333MHZ PC3-10600S SODIMM, serial number M471B 5673 FHO-CH9 SAMSUNG
1. Is it possible to upgrade the RAM and use 4GB DDR other than 1333 MHZ PC3-10600S ?
2. Is the serial number important ? Do I have to get the exact same ?
3. Do i have to use the SAMSUNG brand or any other brand like Crucial is compatible for my mac ?
4. Can i Replace CORE i3 by CORE i5 ? Is it compatible with the initial motherboard ?
Thanks everyone ! Thank you for the very useful tutorial !
Emilie
Upgraded from 4 GB to 16 GB. It worked great thanks for creating this guide.
I kept the 2 original 2GB modules and added two 4GB modules to the slots above each so now the left and right banks each have a 2GB and 4GB RAM module. Seems to work fine, but is this the configuration that allows interleaving to occur?
Before beginning unplug your iMac.
Henry Barnett - 답글
The screws are not phillips #1 as implied above. My phillips#2 bit fit.
John McWilliams - 답글
Yes phillips #2 is the correct Bit
Heath - 답글
Whenever I go this “deep” into any computer that has a motherboard battery, like the CR2032 for this iMac, I’ll add a new battery to my workflow. I’m in the “neighborhood” anyway.
The battery is in a spring-loaded compartment, which requires patience and persistence.
I make sure to test the new battery before installation. (The “3-2-1 Rule” applies: 3 of something means 2, 2 means 1, and 1 means none - I keep spare batteries on hand.)
When I took part in my dual-drive adventure, I also added a thorough dusting (outside/outdoors) - phew!
Carrick - 답글
