소개
Use this guide to replace a damaged glass panel.
도구
부품
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
다른 14명이 해당 안내서를 완성하였습니다.
댓글 2개
You make it sound so easy !! what if the glass is smashed ? it it just a vacum that holds glass in place ? do you use anything adhesive in replacing the glass. (i have seen heat gun method) Thank you for your effort, and clean presentation.
The front glass panel is held in by magnets along the top and sides, plus tabs along the bottom edge that hold it in. If the glass is smashed, the best method is to completely cover the glass panel in packing tape and pry it off instead of using suction cups.
Information sourced from official Apple Technician’s Guide
