주요 콘텐츠로 건너뛰기
iMac Intel 21.5" EMC 2428 Optical Drive Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iMac Intel 21.5" EMC 2428 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • From here, the repair will be easier if you flip the computer around so the base is facing you.
    • Remove the following four screws:
    • One 9.3 mm T10 Torx screw with a large head
    • Three 9.3 mm T10 Torx screws with a normal sized head
  2. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: 2 단계, 이미지 1/2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Pull the optical drive thermal sensor connector straight up from its socket on the logic board. Pull parallel to the board.
  3. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: 3 단계, 이미지 1/2 iMac Intel 21.5" EMC 2428 Optical Drive Replacement: 3 단계, 이미지 2/2
    • Lift the inner edge of the optical drive and maneuver its connector past the GPU frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the right side of the outer case to gain clearance for disconnecting the optical drive cable.
    • Allow the optical drive to hang down as you de-route the optical drive thermal sensor connector from behind the GPU heat sink.
  4. iMac Intel 21.5" EMC 2428 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Disconnect the optical drive cable by pulling its connector away from the optical drive.
    • Remove the optical drive from the iMac.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Walter Galan
694,674 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 296
