소개
Use this guide to replace your logic board's BR 2032 PRAM battery.
부품
지정된 부품이 없습니다.
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 2개
Is this the same battery and procedure for the mid 2011 27”?
Maor Roffe - 답글
is this the solution of fixing the black screen after press the power bottom behind when starting or restart?
