소개
Use this guide to replace a faulty SD Board.
필요한 것
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Use the tip of a spudger to push the SD board cable connector out of its socket.
거의 끝나갑니다!
결론
