소개
Prereq to remove the hard drive brackets.
도구
부품
지정된 부품이 없습니다.
Remove the following screws securing the hard drive bracket to the rear enclosure:
Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
One 9 mm T10 Torx screw.
One 27 mm T10 Torx screw.
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
결론
