주요 콘텐츠로 건너뛰기
소개
Prereq only for removing the logic board, fan and power supply are out.
  1. Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac.
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by two cables, do not attempt to fully remove it from the iMac.
  2. Disconnect the SATA power cable. Disconnect the SATA power cable.
    • Disconnect the SATA power cable.
  3. Unplug the SATA data cable from the hard drive. Unplug the SATA data cable from the hard drive.
    • Unplug the SATA data cable from the hard drive.
  4. Remove the hard drive from the iMac.
    • Remove the hard drive from the iMac.
결론
Walter Galan
674,288 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 130
