이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계에 사용된 도구:iMac Intel 21.5" Cardboard Service Wedge$4.99
iMac 작업을 시작하기 전에: 컴퓨터 플러그를 뽑고 전원 버튼을 10초 동안 눌러 전원 장치의 축전기를 방전하세요.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a pair of tweezers to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
While holding the display up with one hand, use the other hand to unplug the display power cable.
Use a spudger to pry each of the four antenna connectors straight up off their sockets on the AirPort/Bluetooth card.
Remove the two 3.2 mm T5 screws securing the AirPort/Bluetooth card to the logic board.
Push the AirPort/Bluetooth card slightly downwards, 1-2 mm at most.
With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board.
The AirPort/Bluetooth card socket is located a few centimeters below and to the left of the right speaker connector (highlighted in red), on the opposite side of the logic board.
