이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the tip of a spudger to walk the left speaker cable connector out of its socket.
De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
In a similar fashion as the previous step, de-route the combo SATA data/power cable up out of the retaining clip.
Use a pair of tweezers to flip up the metal retaining bracket on the iSight camera cable connector.
Pull the iSight camera cable straight out of its socket on the logic board.
Use the tip of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
Remove the following screws securing the exhaust duct to the rear enclosure:
Two 6.3 mm T8 screws
Two 4.7 mm T8 screws
Remove the four 7.2 mm T10 screws securing the logic board to the rear enclosure.
Use a USB flash drive and/or ethernet cable to keep the logic board aligned while you screw it in.
