주요 콘텐츠로 건너뛰기
iMac Intel 21.5" EMC 3068 Display Assembly Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: 1 단계, 이미지 1/2 iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: 1 단계, 이미지 2/2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  2. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: 2 단계, 이미지 1/3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: 2 단계, 이미지 2/3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  3. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: 3 단계, 이미지 1/3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: 3 단계, 이미지 2/3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: 3 단계, 이미지 3/3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
결론
Adam O'Camb
회원 가입일: 04/11/15
196,299 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 77
