주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement
필요한 것
  1. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Display: 1 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iMac Intel 21.5" Cardboard Service Wedge
    구매
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  2. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 2 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 2 단계, 이미지 2/2
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    • Be gentle! The glass may crack if pried too much. Use a hairdryer to heat the edges and loosen the tape if the room temperatures are low.
  3. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 3 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 3 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 3 단계, 이미지 3/3
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 4 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 4 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 4 단계, 이미지 3/3
    • Continue running the tool up around the top left corner.
  5. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 5 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 5 단계, 이미지 2/2
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 6 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 6 단계, 이미지 2/2
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 7 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 7 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 7 단계, 이미지 3/3
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 8 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 8 단계, 이미지 2/2
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 9 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 9 단계, 이미지 2/2
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 10 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 10 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  11. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 11 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 11 단계, 이미지 2/2
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  12. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 12 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 12 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 12 단계, 이미지 3/3
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  13. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 13 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 13 단계, 이미지 2/2
    • Wedge the plastic card into the top right corner once again and let it stay there to keep the adhesive from resettling.
  14. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 14 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 14 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 14 단계, 이미지 3/3
    • Insert a second plastic card into the gap between the display and frame located at the top left corner of the iMac.
  15. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 15 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 15 단계, 이미지 2/2
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 16 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 16 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 16 단계, 이미지 3/3
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 17 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 17 단계, 이미지 2/2
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 18 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 18 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 18 단계, 이미지 3/3
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  19. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 19 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 19 단계, 이미지 2/2
    • While holding the display up with one hand, use the other hand to unplug the display power cable. Make sure that you pull the cable out from the plastic tab, and not by pulling on the color wires.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  20. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 20 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 20 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 20 단계, 이미지 3/3
    • Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket.
  21. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 21 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 21 단계, 이미지 2/2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  22. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 22 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 22 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 22 단계, 이미지 3/3
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  23. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 23 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 23 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 23 단계, 이미지 3/3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • During reassembly, head over to our display adhesive guide to install the new adhesive.
  24. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Lower Support Bracket: 24 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Lower Support Bracket: 24 단계, 이미지 2/2
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • On at least some EMC 2544 machines, all five screws are the same size.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  25. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 25 단계, 이미지 1/1
    • Remove the lower support bracket from the iMac enclosure.
  26. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Right Speaker: 26 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Right Speaker: 26 단계, 이미지 2/2
    • Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
    • It is useful to push downward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    • Pull the connector downwards to remove it from its socket.
  27. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 27 단계, 이미지 1/1
    • Remove the two 10.0 mm T10 screws securing the right speaker to the rear enclosure.
  28. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 28 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 28 단계, 이미지 2/2
    • Pull the top of the right speaker away from the rear enclosure, about half an inch, to expose the antenna cable running down its right side.
  29. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 29 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 29 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 29 단계, 이미지 3/3
    • Insert the tip of a spudger between the right speaker and the antenna cable that is routed into the speaker's right side.
    • Run the spudger down along the right side of the speaker to pry the antenna cable from its channel in the right speaker.
  30. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 30 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 30 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 30 단계, 이미지 3/3
    • Pull the right speaker straight up about an inch, toward the top of the iMac.
    • Lift the right speaker straight up and remove it from the iMac. This may take some force, both hands and rocking the speaker right and left to get it out.
  31. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Hard Drive Brackets: 31 단계, 이미지 1/1
    • Remove the following screws securing the hard drive bracket to the rear enclosure:
    • Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
    • One 9 mm T10 Torx screw.
    • One 27 mm T10 Torx screw.
  32. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 32 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 32 단계, 이미지 2/2
    • Remove the left and right hard drive brackets from the iMac.
  33. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Power Supply: 33 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Power Supply: 33 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Power Supply: 33 단계, 이미지 3/3
    • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board.
    • Use the tip of a spudger to push each side of the power button cable connector and gently "walk" it out of its socket.
  34. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 34 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 34 단계, 이미지 2/2
    • Gently push upward on each side of the power supply control cable connector with the tip of a spudger to gently "walk" it out of its socket.
  35. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 35 단계, 이미지 1/1
    • Remove the two 7.2 mm T10 screws securing the power supply to the rear enclosure.
  36. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 36 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 36 단계, 이미지 2/2
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    • Tilt the power supply forward.
  37. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 37 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 37 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 37 단계, 이미지 3/3
    • Pull the power supply slightly up and out from the rear enclosure.
    • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  38. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 38 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 38 단계, 이미지 2/2
    • Slide the power supply to the right to clear the screw posts on the rear enclosure.
  39. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 39 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 39 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 39 단계, 이미지 3/3
    • Rock the power supply forward and remove it from its recess in the rear enclosure.
    • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  40. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 40 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 40 단계, 이미지 2/2
    • Flip the top of the power supply towards you to access the DC power cable connection behind the logic board.
    • Squeeze the DC power cable connector tab and pull it straight out of its socket on the back of the logic board.
  41. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 41 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 41 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 41 단계, 이미지 3/3
    • You may find it helpful to set the iMac down on its back on the table for the next couple of steps.
    • Use the flat end of a spudger to push the clip on the side of the AC inlet cable connector inward.
    • While holding on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  42. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 42 단계, 이미지 1/1
    • Remove the power supply from the iMac.
  43. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Fan: 43 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Fan: 43 단계, 이미지 2/2
    • Gently pull the fan cable connector straight away from its socket on the logic board.
  44. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 44 단계, 이미지 1/1
    • Remove the three 12.3 mm T10 shoulder screws securing the fan to the rear enclosure.
  45. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 45 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 45 단계, 이미지 2/2
    • Remove the fan from the iMac.
  46. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Hard Drive: 46 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Hard Drive: 46 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Hard Drive: 46 단계, 이미지 3/3
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by two cables, do not attempt to fully remove it from the iMac.
  47. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 47 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 47 단계, 이미지 2/2
    • Disconnect the SATA power cable.
  48. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 48 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 48 단계, 이미지 2/2
    • Unplug the SATA data cable from the hard drive.
  49. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 49 단계, 이미지 1/1
    • Remove the hard drive from the iMac.
  50. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Hard Drive Tray: 50 단계, 이미지 1/1
    • Remove the single 7.2 mm T10 screw securing the hard drive tray to the rear enclosure.
  51. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 51 단계, 이미지 1/1
    • Remove the hard drive tray from the rear enclosure.
  52. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Logic Board Assembly: 52 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Logic Board Assembly: 52 단계, 이미지 2/2
    • Push on each side of the left speaker cable connector with the tip of a spudger and gently "walk" it out of its socket.
  53. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 53 단계, 이미지 1/2 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 53 단계, 이미지 2/2
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  54. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 54 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 54 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 54 단계, 이미지 3/3
    • In a similar fashion as the previous step, de-route the SATA data and power cables up out of the retaining clip.
  55. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 55 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 55 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 55 단계, 이미지 3/3
    • Use the flat edge of a spudger to flip up the metal retaining bracket on the iSight camera cable connector.
    • Pull the iSight camera cable straight out of its socket on the logic board.
    • This is a delicate connector that can be easily damaged.
  56. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 56 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 56 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 56 단계, 이미지 3/3
    • Use the flat edge of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
    • Note the original positions for each connector when reconnecting the cables.
  57. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 57 단계, 이미지 1/1
    • If brackets secure the four antenna cables, remove the two T5 Torx screws from the brackets.
  58. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 58 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 58 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 58 단계, 이미지 3/3
    • Use the flat edge of a spudger to pry the headphone jack cable connector from its socket on the logic board.
    • Push the cable slightly to the right.
  59. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 59 단계, 이미지 1/1
    • Remove the following screws securing the exhaust duct to the rear enclosure:
    • Two 6.3 mm T8 screws
    • Two 4.7 mm T8 screws
  60. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 60 단계, 이미지 1/1
    • Remove the four 7.2 mm T10 screws securing the logic board to the rear enclosure.
    • Depending on the age and model of your iMac, a T9 driver may work best.
  61. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 61 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 61 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 61 단계, 이미지 3/3
    • Tilt the top of the logic board away from the rear enclosure.
    • Lift the logic board straight up and out of the iMac.
    • Be careful not to snag the board on any of the rear case's screw posts.
    • The I/O boards at the bottom of the logic board will be the greatest challenge. It is recommended to pull gently to avoid any damage.
    • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
  62. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement, Blade SSD: 62 단계, 이미지 1/1
    • Remove the single Torx screw securing the SSD to the logic board.
  63. iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 63 단계, 이미지 1/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 63 단계, 이미지 2/3 iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Replacement: 63 단계, 이미지 3/3
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Dan
회원 가입일: 02/01/12
479,465 평판
안내서 2개 작성하였습니다
Self employed contract worker Self employed contract worker 회원
Business
1 회원
안내서 9개 작성하였습니다
댓글 48개
Many thanks for the tutorial? Very detailed and helpful. Now, my question is, can I replace the existing SSD PCIe blade by ANY PCIe blade?
I mean, the 2017 4K iMacs have a PCIe v3 with 4 channels. Will it admit an older PCIe version (such as v2)?
Aleix - 답글
Apple uses a different interface than the M.2 blades as such you ned to use theirs or either of the two 3rd party drive makers OWC or Transcend
- BeetsTech - The Ultimate Guide to Apple’s Proprietary SSD’s (Apples SSD’s)
- OWC - Aura Pro SSD
- Transcend - JetDrive 820
Dan -
Hello Dan! Many thanks for your answer, but none of the webpages you mention has a blade PCIe SSD compatible with the iMac 4K 2017… :(
Aleix - 답글
I’ve put in few of the BeetsTech blades in with no issues. Are you trying to install the SATA drive?
Dan -
Hi Dan! The initial intention was to replace the current 28GB blade PCIe SSD by a bigger one, 225 or 500GB, and keep the current sATA 1TB drive. This way, I could have a decent and fast FusionDrive, as the current configuration is pretty slow…
Finally, I’ve decided to replace the current 1TB sATA 5400rpm drive by a 1TB sATA SSD, as the total cost is arround the same as replacing the blade PCIe drive. In adittion, I am not 100% sure which blade PCIe drive will work on my iMac… the support guys from OWC say that they don’t have a compatible drive yet :(
Aleix -
댓글 쓰기
조회 통계:
24 시간 전: 25
7일 전: 195
30일 전: 944
전체 시간: 48,660
