주요 콘텐츠로 건너뛰기
iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement
필요한 것
  1. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Install the iMac service wedge: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iMac Intel 21.5" Cardboard Service Wedge
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  2. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Insert the opening tool: 2 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Insert the opening tool: 2 단계, 이미지 2개 중 2개
    • Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  3. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Slice through the display adhesive: 3 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Slice through the display adhesive: 3 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Slice through the display adhesive: 3 단계, 이미지 3개 중 3개
    • Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
    • Be sure to always push with the cutting wheel forward. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 4 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 4 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Continue running the tool up around the top left corner.
  5. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 5 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 6 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Continue along the top of the display.
    • You may want to run the tool back and forth a few times to ensure you completely cut through the adhesive.
  7. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 7 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 7 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 8 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Push the tool down along the right side of the display.
  9. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 9 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 10 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 10 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 10 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  11. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 11 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 11 단계, 이미지 2개 중 2개
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  12. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 12 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 12 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 12 단계, 이미지 3개 중 3개
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  13. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 13 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 13 단계, 이미지 2개 중 2개
    • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  14. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 14 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 14 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 14 단계, 이미지 3개 중 3개
    • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  15. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 15 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 15 단계, 이미지 2개 중 2개
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 16 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 16 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 16 단계, 이미지 3개 중 3개
    • Slide the plastic card toward the center.
    • Stop sliding just before the iSight camera to avoid damaging the camera.
  17. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 17 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 17 단계, 이미지 2개 중 2개
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 18 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 18 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 18 단계, 이미지 3개 중 3개
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  19. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Display Assembly Cables: 19 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Display Assembly Cables: 19 단계, 이미지 2개 중 2개
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • Hold the display with one hand while using your other hand to unplug the display power cable.
  20. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 20 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 20 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 20 단계, 이미지 3개 중 3개
    • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
  21. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Separate the display: 21 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Separate the display: 21 단계, 이미지 2개 중 2개
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  22. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 22 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 22 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 22 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  23. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 23 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 23 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 23 단계, 이미지 3개 중 3개
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
  24. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Remove the lower support bracket: 24 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Remove the lower support bracket: 24 단계, 이미지 2개 중 2개
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  25. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 25 단계, 이미지 1개 중 1개
    • Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
  26. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Fan: 26 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Fan: 26 단계, 이미지 2개 중 2개
    • Gently pull the fan cable connector straight away from its socket on the logic board.
  27. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 27 단계, 이미지 1개 중 1개
    • Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • The uppermost screw has a rubber standoff adhered to its head to support the display—leave this in place.
  28. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 28 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 28 단계, 이미지 2개 중 2개
    • Remove the fan from the iMac.
  29. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Left Speaker: 29 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement, Left Speaker: 29 단계, 이미지 2개 중 2개
    • Gently pull the left speaker cable straight out of its socket on the logic board.
  30. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 30 단계, 이미지 1개 중 1개
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  31. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 31 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 31 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 31 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the power button connector from its socket on the logic board.
    • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
  32. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 32 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the two 10.0 mm T10 screws securing the left speaker to the rear case.
    • Rubber washers keep the screws snug in the speaker even when loosened. You can use tweezers or a fingernail to remove the screws, or simply leave them with the speaker assembly.
  33. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 33 단계, 이미지 2개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 33 단계, 이미지 2개 중 2개
    • Lift the left speaker straight up, until the power button cable is exposed (about 0.5").
  34. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 34 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 34 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 34 단계, 이미지 3개 중 3개
    • Gently de-route the power button cable from its groove in the left speaker.
  35. iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 35 단계, 이미지 3개 중 1개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 35 단계, 이미지 3개 중 2개 iMac Intel 21.5" Retina 4K Display 2019 Left Speaker Replacement: 35 단계, 이미지 3개 중 3개
    • Lift the left speaker straight up and remove it from the iMac.
결론
작성자
1다른 기여자 명과 함께
Adam O'Camb
회원 가입일: 04/11/15
217,168 평판
안내서 416개를 작성함
1가이드 댓글
We snapped the thin wire when taking out the left speaker as it got wedged in the gap. Is there a way to fix this wire?
Gouri Kubair - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 70
전체 시간: 1,335
