주요 콘텐츠로 건너뛰기
소개
Prerequisite only.
부품
지정된 부품이 없습니다.
  1. Gently pull the fan cable connector straight out of its socket on the logic board. Gently pull the fan cable connector straight out of its socket on the logic board.
    • Gently pull the fan cable connector straight out of its socket on the logic board.
  2. Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • The uppermost screw has a rubber standoff adhered to its head to support the display—leave this in place.
  3. Remove the fan from the iMac. Remove the fan from the iMac.
    • Remove the fan from the iMac.
결론
Evan Noronha
회원 가입일: 2015년 02월 05일
208,849 평판
안내서 178개 작성하였습니다
iFixit iFixit 회원
Community
137 회원들
안내서 16,761개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 62
