소개
Follow the steps in this guide to replace the right speaker in a 21.5" Retina 4K Late 2015 iMac.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Hold the display with one hand while using your other hand to unplug the display power cable.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Gently pull the right speaker cable connector straight down and out of its socket on the logic board.
거의 끝나갑니다!
결론
