소개
Use this guide to replace a blown power supply.
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Peel the strip of foam tape off the top edge of the CPU/GPU heat sink framework.
다른 46명이 해당 안내서를 완성하였습니다.
댓글 4개
I didn't do steps 8-10 and it still worked great.
dreamwires - 답글
The guide does not state you need a T6 until you get to the part where you need to remove the display. Please fix that.
Went pretty well… replaced the power supply and it started up on the first try after being idle for 5 years
