주요 콘텐츠로 건너뛰기
iMac Intel 24" EMC 2111 RAM Replacement
필요한 것
  1. iMac Intel 24" EMC 2111 RAM Replacement, Access Door: 1 단계, 이미지 1/2 iMac Intel 24" EMC 2111 RAM Replacement, Access Door: 1 단계, 이미지 2/2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 RAM Replacement, RAM: 2 단계, 이미지 1/1
    • Pull both RAM arms away from the iMac to release both RAM chips from their sockets.
  3. iMac Intel 24" EMC 2111 RAM Replacement: 3 단계, 이미지 1/1
    • Pull both RAM chips out of their slots.
    • During reinstallation, make sure both RAM arms are fully rotated outward before inserting the RAM chips. Use your thumbs to seat the new RAM chips into their sockets and then press the RAM arms back into the iMac.
    • It is normal to encounter a fair amount of resistance when pushing the RAM arms back into the iMac.
결론
다른 20명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
587,996 평판
안내서 619개 작성하였습니다
댓글 3개
Hi, i'd love to make some upgrades but can't remember which imac 24is mine. Where can I read it? Can I switching it on? Thanks
Fabrizio Lazzeretti - 답글
hello, i already have 2GB, is it possible to add more? thank you!
connie dekker - 답글
via Everymac.com
Standard RAM: 1 GB Maximum RAM: 4 GB*
Details: 1 GB of RAM is installed as two 512 MB SO-DIMM modules.
*Apple officially supports 3 GB of RAM, but third-parties have been able to upgrade the system to 4 GB of RAM using two 2 GB memory modules
emaginechild -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 16,391
