주요 콘텐츠로 건너뛰기
iMac Intel 24" EMC 2111 Right Speaker Replacement
필요한 것
  1. iMac Intel 24" EMC 2111 Right Speaker Replacement, Access Door: 1 단계, 이미지 1/2 iMac Intel 24" EMC 2111 Right Speaker Replacement, Access Door: 1 단계, 이미지 2/2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 Right Speaker Replacement, Front Bezel: 2 단계, 이미지 1/1
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
  3. iMac Intel 24" EMC 2111 Right Speaker Replacement: 3 단계, 이미지 1/2 iMac Intel 24" EMC 2111 Right Speaker Replacement: 3 단계, 이미지 2/2
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  4. iMac Intel 24" EMC 2111 Right Speaker Replacement: 4 단계, 이미지 1/3 iMac Intel 24" EMC 2111 Right Speaker Replacement: 4 단계, 이미지 2/3 iMac Intel 24" EMC 2111 Right Speaker Replacement: 4 단계, 이미지 3/3
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  5. iMac Intel 24" EMC 2111 Right Speaker Replacement: 5 단계, 이미지 1/1
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  6. iMac Intel 24" EMC 2111 Right Speaker Replacement: 6 단계, 이미지 1/3 iMac Intel 24" EMC 2111 Right Speaker Replacement: 6 단계, 이미지 2/3 iMac Intel 24" EMC 2111 Right Speaker Replacement: 6 단계, 이미지 3/3
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  7. iMac Intel 24" EMC 2111 Right Speaker Replacement, Display Assembly: 7 단계, 이미지 1/2 iMac Intel 24" EMC 2111 Right Speaker Replacement, Display Assembly: 7 단계, 이미지 2/2
    • Peel the two highlighted EMI shield tabs off the frame of the LCD.
  8. iMac Intel 24" EMC 2111 Right Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the two T6 Torx screws securing the display data cable to the logic board.
  9. iMac Intel 24" EMC 2111 Right Speaker Replacement: 9 단계, 이미지 1/1
    • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
  10. iMac Intel 24" EMC 2111 Right Speaker Replacement: 10 단계, 이미지 1/2 iMac Intel 24" EMC 2111 Right Speaker Replacement: 10 단계, 이미지 2/2
    • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
    • De-route the inverter cable from its location next to the CPU fan.
  11. iMac Intel 24" EMC 2111 Right Speaker Replacement: 11 단계, 이미지 1/1
    • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
    • Remove the eight T8 Torx screws securing the display assembly to the rear case.
    • It is helpful to use a thin magnetized screwdriver to remove these screws.
  12. iMac Intel 24" EMC 2111 Right Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the display assembly from the iMac.
  13. iMac Intel 24" EMC 2111 Right Speaker Replacement, Right Speaker: 13 단계, 이미지 1/2 iMac Intel 24" EMC 2111 Right Speaker Replacement, Right Speaker: 13 단계, 이미지 2/2
    • Peel back the piece of EMI tape connecting the bottom edge of the right speaker to the metal frame of the iMac.
    • Peel the tape away from the lower corner of the right speaker.
  14. iMac Intel 24" EMC 2111 Right Speaker Replacement: 14 단계, 이미지 1/2 iMac Intel 24" EMC 2111 Right Speaker Replacement: 14 단계, 이미지 2/2
    • De-route the right-hand speaker's cable from between the logic board and the optical drive fan.
    • Disconnect the cable from the logic board.
  15. iMac Intel 24" EMC 2111 Right Speaker Replacement: 15 단계, 이미지 1/1
    • Remove the 26 mm T10 Torx screw securing the right speaker to the iMac.
  16. iMac Intel 24" EMC 2111 Right Speaker Replacement: 16 단계, 이미지 1/1
    • Pull the right speaker away from the logic board and remove it from the iMac.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,296 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,167
