주요 콘텐츠로 건너뛰기
iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement
단지 전제 조건
이 안내서는 다른 안내서의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement, Display Panel: 1 단계, 이미지 2개 중 1개 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement, Display Panel: 1 단계, 이미지 2개 중 2개
    • Disconnect the LCD temperature sensor by pulling the connector straight out of its socket on the logic board.
    • If necessary, de-route the LCD temperature sensor cable from behind the logic board.
  2. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 5.3 mm T6 Torx screws securing the display data cable to the logic board.
  3. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the display data cable connector from its socket on the logic board by pulling the attached plastic tab towards you and away from the iMac.
  4. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 4 단계, 이미지 2개 중 1개 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Lay the iMac down on a table before you remove the LCD so that it doesn't fall.
    • Remove the eight 12 mm T8 Torx screws securing the display panel to the rear case.
    • Lift the right side of the display panel a few inches up from the iMac.
    • Do not lift the LCD all the way up; there are still connectors attaching the LCD to the internals.
  5. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 5 단계, 이미지 2개 중 1개 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 5 단계, 이미지 2개 중 2개
    • With the LCD lifted, disconnect the LCD cable by pulling down.
    • The LCD cable is attached to the underside of the power supply; be careful where you put your fingers so you don't get zapped by a capacitor.
    • On reassembly, you may find it helpful to remove the power supply, reconnect the LCD power cable, and then reinstall the power supply.
    • Alternatively, the LCD power cable can be disconnected from the LCD, rather than the power supply.
  6. iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 6 단계, 이미지 2개 중 1개 iMac Intel 24" EMC 2134 and 2211 Display Panel Replacement: 6 단계, 이미지 2개 중 2개
    • Continue to lift the LCD from the right side.
    • Remove the LCD.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,865 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,583개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 17
전체 시간: 2,961
