소개
Remove the glass panel to gain access to your iMac's internals.
필요한 것
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick two suction cups to opposing corners of the glass panel.
Gently pull the glass panel straight up off the iMac.
The glass panel is somewhat thin and should come away quite easily without much force so be gentle.
To reinstall the glass, I lined up the bottom edge first, then pivoted the top in. The magnets pulled it quickly into place.
다른 32명이 해당 안내서를 완성하였습니다.
Save $15 dollars and use a plunger. Works perfectly.
Michael Ybarra - 답글
Even better and more elegant: go to a household shop and buy two transparent plastic bathroom baskets with two suction cups each. I found them in Xenos in the Netherlands (maybe also in Germany).
freed - 답글
Perhaps not so elegant but equally effective without any adverse effects to either... try a vacuum cleaner.
Andrew Dobson - 답글
The same kind of suction cups are available from Harbor Freight Tools (Item # 62715) for $2.99 each or $5.98/pair (plus sales tax).
Bob Atkinson - 답글
