주요 콘텐츠로 건너뛰기
iMac Intel 24" EMC 2134 and 2211 RAM Replacement
필요한 것
  1. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, Access Door: 1 단계, 이미지 1/1
    • Loosen the single Phillips screw in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: 2 단계, 이미지 1/2 iMac Intel 24" EMC 2134 and 2211 RAM Replacement, RAM: 2 단계, 이미지 2/2
    • Use the tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
    • Pull the black plastic RAM tab away from your iMac to eject the RAM module.
  3. iMac Intel 24" EMC 2134 and 2211 RAM Replacement: 3 단계, 이미지 1/1
    • Grab the RAM module by its edges and pull it straight out of its slot.
    • If two RAM modules are installed, repeat this process for the other chip.
결론
다른 52명이 해당 안내서를 완성하였습니다.
Brittany McCrigler
회원 가입일: 03/05/12
88,229 평판
안내서 132개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,643개 작성하였습니다
5 댓글
I believe the EMC2211 model requires PC2-6400 RAM chips instead of the PC2-5300 proposed here.
Edouard Gilbert - 답글
EMC2134 requires PC2-5300 as specified here. PH1 worked ok. Need to give RAM tabs a pretty firm pull to initially unseat, then it is easy to slide RAM back.
lcgillies - 답글
I don't see any 4 GB RAM chips? I currently have a 2 GB and 4 GB. Was thinking about changing out the 2 GB for a 4 GB. Would it support two 4 GB RAM chips? Do you not sell them?
ericgossick - 답글
Ericgossick: according to Apple the most ram you can have is 4 GB. I have heard you can install 2 GB & 4 GB ram chips & the computer will operate normally. If you install 2 (two) 4 GB ram chips the computer will only use 6 GB; it will never use 8 GB. That's just what I've heard. Hope this helps.
davidfoster11 - 답글
Does anyone know if one bank is better than the other for the 4G stick if one is maxxing out their RAM?
Alistair Prewett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 82
전체 시간: 37,469
