주요 콘텐츠로 건너뛰기
iMac Intel 24" EMC 2267 RAM Replacement
필요한 것
  1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: 1 단계, 이미지 1/1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw PH#2 in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: 2 단계, 이미지 1/2 iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: 2 단계, 이미지 2/2
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 24" EMC 2267 RAM Replacement: 3 단계, 이미지 1/1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
결론
다른 35명이 해당 안내서를 완성하였습니다.
johann beda
회원 가입일: 09/13/10
2,438 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 52
전체 시간: 25,448
