소개
If you are using the iMac 27" late 2009 or 2010 model for games, you might want to upgrade your graphics card to the 6 series of the last 2011 model.
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
Be very careful with the display cables, for they can be damaged easily.
Remove the temperature sensor cable from the Hard Drive, so that the card can be removed.
Remember the position of this cable! iFixit tip: the cable must later be reinstalled closest to the SATA connector. The black cable needs to point up, towards the LCD.
Now remove these 3 T9 Torx screws from the graphics card bezel.
Locate the large heatsink from the graphics card, which should be right above your DvD drive
Remove the single screw there holding it in place
Carefully remove the graphics card temperature sensor cable from underneath the motherboard
Remove the metal bezel from the graphics card. Only a couple of screws hold it in place
Store away your graphics card safely in case you need it again or want to reinsert it
The second image shows both the 4 and 6 series side by side. A little difference in height makes some extra work necessary (see next step)
As the 6 series is slightly higher we need to make a little space on the plastic holder which is beneath the card
Remove the plastic part which is shown on the 2nd picture by removing one screw and carefully pull it from the aluminium case
Its fastended with tape, so don't worry, you can't break anything
Some wiggling and navigating it from the cables and you should have it in your hands
You see the rectangular space where the large cable goes through. Use a saw or other tool to make it about 5mm wider and 2-3mm deeper
The third image shows the final result we want to achieve
The primary reason for thi step is the heatpipe of the 6 series which takes more space
Note: this is ONLY necessary on the late 2009 model, 2010 models already got enough room!
Apply the metal bezel to the new 6 series graphics card. Make sure its aligned properly
Now insert the 6 series graphics card carefully.
Make sure you don't damage the upper side of the mother board when reinserting
When in place fix it by the 3 screws
Reinsert the temperatur sensor cable. You need fine hands or a good tool to do so. Be patient with this step
Reassemble the LCD display as explained on ifixit.
No other work needs to be done. As you removed the power cable the SMC should reset, which is the chip configuring your hardware
If all goes well you should be greeted with a welcome screen and "about this mac" should show the image to the left
Note: I also replaced the DvD drive with a 256GB SSD which can be done easily during the installation process
Last tip: if you remove the DvD drive for a SSD make a minimal bootcamp partition and install windows on it. It will save you a lot of trouble if you ever need one. Believe me, simply do it, installing bootcamp with no DvD drive is a pain.
다른 92명이 해당 안내서를 완성하였습니다.
댓글 121개
works perfectly ;-) just be slow and precised
Just be noticed that this upgrade not work for iMac 27 late 2009 equipped with core 2 duo CPU, but only with the i5 and i7 CPU one!
Paolo -
Did you know you can add an additional SSD drive WITHOUT needing to remove your Optical drive? It installs vertically just to the right of your HDD. I just performed this upgrade last weekend. I believe you can do this to 2009 and up models.
Regretfully Not on the iMac late 2009, because the motherboard has only 2 SATA ports, not 3 like the 2010 and later models...
Just a question: with this mod, are you able to use Airplay Mirroring in Mountain Lion? Since the inhability to use it on these macs is GPU-related, virtually with this Graphic card you may be able to enable it... Let me know please!!
