소개
Use this guide to replace a faulty SD Board.
필요한 것
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Grasp the SD board cable connector with a pair of tweezers and pull it straight away from its socket on the SD board.
다른 2명이 해당 안내서를 완성하였습니다.
