소개
Remove the access door to replace RAM modules.
도구
부품
지정된 부품이 없습니다.
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
다른 12명이 해당 안내서를 완성하였습니다.
댓글 한 개
Easy mode. Note that the bits is called PZ1 most screwdriver sets. Also known as Japanese Phillips, the bid comes to a + instead of to a point. A 2.0 flathead will also turn the screw
