주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
iMac Intel 27" EMC 2390 Display Replacement
필요한 것
  1. iMac Intel 27" EMC 2390 Display Replacement, Glass Panel: 1 단계, 이미지 1/3 iMac Intel 27" EMC 2390 Display Replacement, Glass Panel: 1 단계, 이미지 2/3 iMac Intel 27" EMC 2390 Display Replacement, Glass Panel: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    구매
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
  2. iMac Intel 27" EMC 2390 Display Replacement: 2 단계, 이미지 1/3 iMac Intel 27" EMC 2390 Display Replacement: 2 단계, 이미지 2/3 iMac Intel 27" EMC 2390 Display Replacement: 2 단계, 이미지 3/3
    • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 27" EMC 2390 Display Replacement, Display: 3 단계, 이미지 1/1
    • Remove the eight T10 Torx screws securing the LCD to the outer case.
  4. iMac Intel 27" EMC 2390 Display Replacement: 4 단계, 이미지 1/3 iMac Intel 27" EMC 2390 Display Replacement: 4 단계, 이미지 2/3 iMac Intel 27" EMC 2390 Display Replacement: 4 단계, 이미지 3/3
    • Carefully lay the iMac stand-side down on a flat surface.
    • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
    • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
    • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
    • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
  5. iMac Intel 27" EMC 2390 Display Replacement: 5 단계, 이미지 1/2 iMac Intel 27" EMC 2390 Display Replacement: 5 단계, 이미지 2/2
    • Using your fingers, carefully pull the vertical sync cable out of its socket on the LED driver board near the top left corner of your iMac.
    • Be sure to pull the connector parallel to the LED driver board, straight out of its socket.
  6. iMac Intel 27" EMC 2390 Display Replacement: 6 단계, 이미지 1/1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
  7. iMac Intel 27" EMC 2390 Display Replacement: 7 단계, 이미지 1/1
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
  8. iMac Intel 27" EMC 2390 Display Replacement: 8 단계, 이미지 1/1
    • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  9. iMac Intel 27" EMC 2390 Display Replacement: 9 단계, 이미지 1/1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case.
결론
다른 28명이 해당 안내서를 완성하였습니다.
Brett Hartt
회원 가입일: 04/12/10
127,941 평판
안내서 143개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,299개 작성하였습니다
댓글 6개
Hard to learn, easy to master. There are a lot of trap cables that are not very long. For best results, I like to use cardboard hard drive boxes to prop up my LCD display to a 30° angle so I can reconnect cables with both my hands.
Kevin McCartney - 답글
Does anyone know if the display from a 2011 27" iMac is compatible with a 2010 27" iMac? The 2011 in my office died, but the 2010 still works fine, albeit with color trouble due to a malfunctioning display.
kazoodac - 답글
They are not. Sorry.
Al
Alan Ullman -
I can disassemble the LCD backlight to clean the dust that does a bad ghost, some of you have already done it
lucaramponi02 - 답글
Hello ! Do you have, any idea where I can buy the display replacement?
Javier Malpartida - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 36
30일 전: 200
전체 시간: 52,308
