이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:Heavy-Duty Suction Cups (Pair)$14.95-
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 3개
Goods councils.
The glass of my iMac is broken and I want to fix it now. I consider to use a frame instead of a new glass in order to reduce reflections. I saw such a frame on macframe dot com and berlin1000 dot com. I wonder if anybody knows the exact measurements of the glass or has a technical drawing of it. If so, I would be able to laser cut it on my own.
Do everything in your power to avoid touching the inside of the glass with your fingers, or the LCD. Please give me his fingerprints is like washing and oiled animal with water
